Patch 0.5 has pushed Path of Exile 2 into a weird but interesting spot: still Early Access, still messy in places, but now much easier to actually follow a build without keeping three browser tabs open. Return of the Ancients brings the Runes of Aldur league, a refreshed Atlas, new Ascendancies, more than 100 new Runes, Unique item changes, and the in-game Build Planner. For regular players, that last bit matters a lot. You grab a build file, drop it in the right folder, and the game can show you passive pathing and skill notes from inside the client.
Sacrosanctum is all about steady recovery
Sacrosanctum is a Unique Corvus Mantle, and it's built for that Strength and Intelligence middle ground. Armour, Energy Shield, Strength, Intelligence, Chaos Resistance, Spirit, then the real hook: Damage taken Recouped as Life, with that same Life Recoup also applying to Energy Shield. The current roll to care about is 10-20%, not the old 5-10% value some listings still show. That changed in patch 0.4.0, and it's a big deal. A 20% roll doesn't just give better Life recovery over time. It also feeds the Energy Shield side through the Unique line. So yeah, if you're shopping for one, don't treat every copy like it's the same chest with slightly different armour numbers.
That old listing can trick you
Check the Recoup roll first. Then look at Spirit, Chaos Resistance, and the Armour/Energy Shield percentage.
What the Build Planner actually does
The new Build Planner isn't Path of Building. Not even close. It's more like a proper in-game guide layer, which is honestly what a lot of players needed. The usual process is simple enough: download a.build file, put it in Documents/My Games/Path of Exile 2/BuildPlanner, open the Skills tab, hit the Build Planner icon near the filter area, and pick the build from the drop-down. When it works, the tree shows what to take, and creators can add notes for skills or progression. Poe.ninja can already export passive trees and skills, though items aren't included yet. Maxroll, Mobalytics, Poeplanner, poe2.dev, and forum creators are also part of the early ecosystem, depending on the build you're chasing.
Runes, Atlas changes, and the new endgame rhythm
Runes of Aldur adds encounters where Ezomyte remnants can be inscribed with symbols. Pick a symbol, raise nearby dead monsters, then deal with the reward and the danger you chose. Verisium ties into the new crafting options, including Runic Ward, which can protect you when Life runs out. Runic Skills also spend Runic Ward instead of Mana or Life, which opens some odd build ideas. On the Atlas side, fixed points of interest make farming feel less like wandering blind. Fortresses, Masters, reworked Breach, Delirium updates, and Ritual reward changes all push the endgame toward more deliberate routing. You're still grinding, of course. It's PoE. But at least the map chase has clearer signposts now.
What still isn't nailed down
There are still blanks players shouldn't pretend are solved. No reliable source confirms a fixed Sacrosanctum farming boss, a league-only rule, or a deterministic recipe. No source confirms that Sacrosanctum can be upgraded through the 0.5 Unique upgrade systems either. Recoup stacking with other sources, Demon Form, Energy Shield recovery scaling, and hard limits also need proper testing. If you're gearing around it, buy the strongest roll you can justify, compare listings carefully, and keep some budget back to buy PoE2 Currency when the market moves after build creators start pushing new 0.5 setups.
