一、网络设置,保证板卡可以上外网。
root@elf2-desktop:/home/elf# nmcli con mod 'Wired connection 1' ipv4.method manual ipv4.addresses 10.10.19.45/24 ipv4.gateway 10.10.19.254 ipv4.dns 8.8.8.8 connection.autoconnect yes
root@elf2-desktop:/home/elf# nmcli con up 'Wired connection 1'
Connection successfully activated (D-Bus active path: /org/freedesktop/NetworkManager/ActiveConnection/4)
二、安装PYQT5
elf@elf2-desktop:~$ sudo apt install python3-pyqt5 pyqt5-dev-tools
三、测试例程
import sys
from PyQt5.QtWidgets import QApplication, QWidget
if __name__ == '__main__':
    app = QApplication(sys.argv)
    window = QWidget()
    window.setWindowTitle('PyQt5 Test')
    window.setGeometry(100, 100, 300, 200)
    window.show()
    sys.exit(app.exec_())
四、执行环境变量,测试应用
elf@elf2-desktop:~$ export DISPLAY=:0.0
elf@elf2-desktop:~$ python3 c.py
